Coating an internal chimney
19 Sep 2009
Aberdeen
Hello All
We have a chimney in the middle of our house which is exposed (see photo).
The bricks are quite dirty and the lime/cement morter rubs on on clothes etc when touched.
As a test, I put a little clear varnish on a part of the chimney and that sorted the problem.
Is there an issue with using a clear matt varnish to coat the entire brick work? The chimney does not get hot at all when used (very occasionally). A builder told me its no problem at all, but just interested to check.
Cheers and thanks to anyone!
Al
View media item 85157 View media item 85157
There's no fire opening for using the flue, unless the floor below has a fire opening thats sometimes used with a fire of some kind?
The partially demolished chimney breast is definitely not best practice.
You could varnish the brickwork but the varnish would begin to perish pretty rapidly - that kind of thing was slightly popular in the seventies and it looked cheap and tatty.
Have you thought about simply plastering the brickwork?
Hot fumes in the remaining flue - if it is a remaining flue - should have no effect on any varnish.
Has the old flue been vented top and bottom?
