coded deadlock? Mum locks door and leaves key in
18 Jul 2006
London
My mum continually deadlocks the door and leaves the key in the lock which has resulted in neighbours having to break in.
Sadly telling her not to hasn't changed things! (parents eh? Can't tell em, can't cart em off! : ) )
Can you get coded deadlocks for doors so it can be opened from outside without needing to be able to get a key in? She also leaves the lock button on the night latch as well just to make things worse.
I'll ask at the lockshop but wanted some independent views on this too.
Thanks in advance
Marko
I bought one of these for a flat.
http://www.digidoorlocks.com.au/product_2300.html
It cose me about £55 from ebay (they shipped from Taiwan I think).
You can set a four digit code for your mum, and a master code for yourself (which enables you to change the four digit code you give your mum in case she tells somebody!). So to enter, juts press four digits, and to lock from the inside, just press the button or turn the latch.
If it is an oustide door, your probably want to search for a differnet Milre make, that has a cover ...
Thanks in advance
Marko
Why do neighbours break in when she is at home with door locked?
Change the locks/cylinders to an thumb-turn internally, so that she does not have to use a key to lock the door
Im with Woody
A thumb turn barrel is good because its permanntley on the door so no worry about her loosing missplacing the key once inside wether the dioor is locked or not.
Also when the door is locked from the inside you can ALLWAYS open it with a key from the outside .
Would your mom be ok remembering the code on a keypad lock?
The only thing i see against a thumbturn is that insurance companies dont like them because once inside the house an unwanted guest can easily open the front door on the inside to let themselves out etc, as opposed to the dead lock of a normal barrel.
Cheers Alan
Sadly telling her not to hasn't changed things! (parents eh? Can't tell em, can't cart em off! : ) Marko
Easy solution. Saw a tiny slot on the end of the key. When she leaves key in lock, they just have to take a slim flat screwdriver to turn the key and push it back inside.
Better answer is change to a cylinder operated deadlock.
Fit a "Hotel" cylinder EVVA ASSA and others make them.
Then a key will work from outside even if one is still inserted inside.
