We live in a 2 year old house, and the main bathroom is often very cold indeed. Rest of house fine, although this is one of 3 rooms with ceiling fan and had noticed draught coming through so in this room I've sealed up the fan but still a problem. Our neighbour has an identical house but has said they do not have the problem, the only difference is that their bathroom has wood fittings/cabinets whereas we have stone.
Who could help with this? Are there insulation/heating experts? A plumber came out and suggested we needed a higher BTU radiator but could it be other issues?
A few notes:
i) Travertine stone floor, and stone up to a granite top (stone where others might have cabinets, so a gap and then breeze block then outside - don't think any insulation in the gap beneath the granite top).
ii) Inset spotlights (so insulation in ceiling is gappy where it can't be close to light fittings)
iii) External walls on two sides.
iv) Reasonably large room with a single heated towel rail (approx 1800 BTU I suspect)
v) Windows are wood, double glazed, but suspect not particularly high quality - that said no obvious draught from them although near them the air is fairly cold.
vi) As above, fan which had previously had cold air dropping down through it has been sealed up (with plastic and tape)
Any suggestions? We were thinking of getting the floor replaced with underfloor heating and keeping the radiator...
Paul
A few notes:
Paul
