hi.
have a prob with the cold water feed form the loft to the boiler.we took of a rad to tile behind.after putting it back on. the boiler making a woshing sound,rads down stairs are fine.up stairs hot at bottom cold at top.
manweb engineer came out and has said the cold feed from the loft to the bolier is blocked. quoted £600 to do it
now he has said that it could be fixed if we back filled from the overflow vent pipe that is the same tank in the loft.he said it is just a case of pouring water down slowly while someone bleeds the radiator.he said it wouldnt cure the blockage but would stop the noise.
would this be a solution in the short term to getting the system working again and is it easy to do???????????
any help would be gratfully recieved
