Guys, I know there have been many discussions on this but none of the answers worked for me.
I have a radiator that only gets warm on the flow but the rest of the rad is stone cold, I have changed the valves and if I turn all of the other rads off then it works. But when I turn the other rads on and try to balance the system, the same rad goes cold again. If i crack open the return valve then the rad gets hot through water flow and not just heat transfer.
The system is gravity fed microbore (god I hate the stuff).
I have power flushed the system (twice), after the second time, the boiler was getting up to temprature to quick and pushed the water back up into the F & E tank then kept cutting out.
I have replaced the pump and valve, also tried putting the pump on to push the water the other way, all with no sucess. The rad is not even last in the run.
Any other solutions i'm missing?
