Boiler died so i replaced it myself with a wall mounted number (oil fired). Since then (october 2007) I've a downstairs radiator in the hall that does not get hot. I've bled the rad and no air. If I turn off all other rads it still remains cold. They all are fitted with TRVs
The radiator in the spare room above it over the course of a week or so fills with air and obviously goes cold. I bleed this one and much air escapes and eventually it heats up. THe hot water tank also has a TRV fitted as there is no option to hot water only so during warmer months i just use an immersion heater on a timer.
So has anyone a series of things I can do please to work out the problem. I've lived in the house about ten years and the heating wasn't newl when i moved in.
Thanks,
Tin B
Thanks,
Tin B
