Had a new indirect cylinder fitter during last summer and since the central heating system has an intermittent fault whereby I struggle to warm them up sufficiently.
It appears there maybe an air lock somewhere in the pipework.
Today for about the third time, I have completely drained the whole system, shut down all rads both upstairs and downstairs, refilled, balanced and bled all radiators, opening the one nearest the downstairs boiler and gradually working outwards with the downstairs rads only.
They worked to half capacity for about two hours then suddenly all of the ones started (8) all went cold although the boiler was still functioning,
Recently fittd a new pump which is scalding hot to touch and hot tap water also is scalding hot.
Is the next step to gently pressure the system in reverse using a mains hose pipe? If so I would welcome advice.
The cylinder was replaced by a professional, is it possible to connect the flow and return incorrectly and if so would this be the possible cause of my problems?
Colin (redcap)
Colin (redcap)
