Cold radiators
19 Oct 2005
Cheshire
Hi
hope someone can help! my central heating has been off for some time (over the summer) but have switched it on today and two radiators down stairs do not get hot,one of them was replaced while it was off but not the other one
Robin b :mrgreen:
did you bleed them when you filled the system back up? Chances are they are full of air. Get a bleed key and tap off the air. then, if its a sealed system, check the pressure and fill if nessecary.
have been able to get one radiator going it was a sticking thermostat valve but the other rad seems to have a blockage in the pipe as it is cold going to the rad anyone any ideas?
Turn one valve off on all your other radiators and usually it will force the water around this rad getting rid of your airlock :roll:
