cold tap is warm when heating is on
27 Oct 2009
hello, my house has a conventional open vent system. whenever the heating is on, the cold tap in the bathroom (which is fed from the storage tank in the loft) comes out hot. any ideas what this could be?
cheers, Rich
ah so its just the heat from one pipe transferring to the cold supply? smart move! anyway thanks for the advice
Seco is probably right, but if it doesn't run cold after running off some water, there may be other problems causing the heating system to heat the cold storage cistern.
Plastic cisterns aren't designed to handle hot water!
how long are we talking for running off, like a few litres?
yes shouldn't take much.
you can check the tank in the loft that the waters cold.
