Cold water fed from loft tank
16 Feb 2004
Salutations
I would appreciate some advice, I have just moved into a town house built circa 2002. I have recently discovered that the cold taps above the ground floor are fed from the loft tank uuughh.
Can I just block the feed from the tank and bypass to the cold water feed to the tank so that all of the house's cold water is fed from the mains.
I do have 2 x power showers fed with hot from the cistern via essex flanges I don't know if this will be of any consequence. Any advice will be most welcome.
Regards
Willard
you could mains feed the cold
they will still need to be tank fed hot and cold :wink:
