hi all, ive just had to drain down a central heating system due to a bad leak. i drained down at the floor mounted boiler in the kitchen. the central heating system needs to be replaced so needs to be dry. system is indirect with f and e tank and main water tank in attic. since draining down i have poor water pressure on the cold taps apart from the kitchen tap which is on the rising main. the only valve that was closed is the f and e feed. is the problem an air lock? hot water is fine via immersion heater. any help would be appreciated.
