Cold Water Problem
9 Aug 2007
Belfast
Hi, I have just changed all the taps in my bathroom, the basin ones and the two free standing taps on the bath for a mixer style with a shower head.
Before the tap replacement - I turned off the water supply (downstairs stop valve) and the tap down stairs went off, I then went into the loft and turned off three valves (two from the cold water storage tank and 1 feeding another smaller - header ? tank). Both taps downstairs now don't flow, hot in the bathroom doesn't but the cold upstairs took ages to drain the cold water tank - which drained and didn't refill.
After the tap replacement, I turned on all 4 valves. Downstairs hot and cold are running fine. Upstairs hot is running fine, cold at the start was non-existent. I left the cold water storage tank to refill, which it did, now the cold water tap runs quickly for a second, then really slowly until it almost stops. If I turn the cold water tap on, the toilet cistern stops filling, when I turn it off it starts again - very slowly. The bath mixer cold does the same, quick, slow, trickle, stop. How can I fix this and what do you think had happened?
Thank you for all your help.
Classic airlock.
Easy to sort out if it's a hot airlock, not so easy on the cold
try holding the palm of your hand over the bath tap spout and opening the hot and cold tap at he same time, the hot passing through the spout may clear the cold airlock
its the cold tap that's locked, not the hot, thanks for the quick replies though - what do I do for a cold?
wont work if the cold is tank fed :idea:
connect the wmc valves together with one of the hoses and open both valves
should blow it out
dont do it for to long tho :idea:
Try what I have suggested, you will notice that the WC will start filling rapidly, wait for it to fill up, then wait some more, keep your hand under the spout the whole time- totally seal the spout off with your hand.
should blow it out
erm, what do you mean by wmc valves?
should blow it out
You don't necessarily need mains pressure to blow out the airlock, I have had success with this method, besides the OP has described a cold airlock, what you are suggesting is for a hot airlock
I would seriously try my method, it has proven to work.
I have also had success by holding a small piece of hose pipe onto the Cold storage cistern ballvalve spout and the other end down the offending tank connector- poked right inside there. Sounds ridiculous but does work
this is true have done it myself :wink:
OK, I tried this about three or 4 times, the toilet did indeed start filling quicker, but once I let go the cold tap was still running very slowly. How long should I hold my hand there for?
first ignore my last post :lol: :lol:
connect a hose from the cold main to the tank fed tap and same procedure
wet vac on the offending tap has been known to work as well
Do you mean a hosepipe from the downstairs cold tap to the upstairs cold tap? Then open both of them?
Yes, the mains pressure will clear the airlock, even from an outside tap if that's easier
