- Joined
- 18 Feb 2007
- Messages
- 1,410
- Reaction score
- 79
- Country
I needed to replace a hot and cold taps in my bathroom, As there was no local isolation valves for these taps, it was necessary for me to Isolate the Cold water supply tap, and as a precaution I also Isolated the supply entering my Hot Water cylinder. There was a very odd result to this Isolation which was that two Cold water taps did not isolate completely. I assumed that there was residual pressure in the cold water piping so I opened several cold water taps around the house. Most successfully Isolated, but two on the ground floor reduced flow to about 10% of full flow. I let them drain for maybe an hour but two taps continued to discharge cold water maybe 5% full flow. All other taps isolated as expected. I cannot understand how, after isolation of the cold supply to my house that two cold water taps continued to discharge cold water. Just where the source of this cold water remains a mystery to me.
As all upstairs tap did successfully isolate, I went ahead with the job in hand, after which I opened the supply Isolation valve so Job Done.
The question is, Has anyone any idea why ONLY two cold water taps continued to discharge cold water even when the supply isolation valve was fully closed. The Supply isolation valve was confirmed as being fully closed because all other cold water taps on the system when opened, did not discharge any water.
