cold water tank valve options
30 Sep 2004
We have two large(500l) cold water tanks with ball operated float valves that have started leaking due to ball valve not shutting off completely. Valves are about 6 years old.
Rather then just replace them or some washer I was wondering if there were any alternatives that are more reliable and/or quieter. E.g. for our toilets I recently replaced some with valves from B&Q that fill very quietly and shut off very quickly when full. Is there anything similar that can be used in a cold water tank ?
The supply pipes are 22mm so I think the current valves are 3/4. They are brass and side inlet with plastic balls. The tanks are interconnected.
Another consideration is to have a high fill rate as the tanks feed a large bath and power shower so if both are run the water flow rate can be quite high. I believe at the time the tanks were installed plumber said the valves were high flow rate, although he was a bit dodgy to be honest.
