Coldstream 500 or Altecnic ultra 500
3 Mar 2010
London
Hi does anyone out there know which is better ?..... The Coldstream or Altecnic ultra, mains cold water accumulators. I know the Coldstream is more expensive but does this mean its better long term value ??.
I understand the Altra has a replacable diaphram, is this also the case with the Coldstream 500?? would appreciate any feedback on this.
thanks saulw
Nothing to choose between them, the Coldstrem uses a high quality vessel, so the diaphragm shouldn't fail, the altecnic does have a replaceable diaphragm, but you would have to remove the vessel to an area where you could make a mess! (Water & sludge) I know iv'e had to change a few!
Personally I would go with the unit that has dimensions that fit your needs :wink:
Thanks Boilerman2, would you therefore say the coldstream has less chance of diaphragm trouble, in your experience ?. Should the Coldstream diaphragm need replacing is this possible ? or would it just need cleaning ?. Have been quoted £870 for the Altecnic and £200 more for the Coldstream. Must say the Coldstream seems to have a better spec !. Size is not a problem as I am building a housing to suit.
Thanks again Saulw
