Collated Screws 20 mm or less
2 Aug 2013
Cornwall
Hi
I looking to put 6 mm ply on 18mm floorboards and trying to find 20 mm collated screws, someone mentioned a manufacturer that did 19mm but i cannot seem to find.
Any ideas welcome.
Cheers
Andy
but they will go into floor gap and the way this place was done you can be sure pipes right at surface
Regards
A
As I see it, you either risk the plywood working loose, or puncturing a pipe/cable.
Try 25mm screws? Chances of hitting a pipe fairly slim. As for cable, you really need to check.
ok thanks i got 37 sheets to put down (80 plus sq meters) so i just worry it will be hard to check all well and its got plastic pipes
thanks for help
