college project
11 Feb 2009
Fife
i have a college project in which i have to plan an install of a workshop in safe condition and hazardous condition. i was wondering i any one knew wat type of enclosures the machines would have to have wat kind of distribution board to use. and wat mcb's to use and where to find all of these and get prices. in the project i have to install 8kw motor for lathe, 5kw motor for milling machine a 2.5 kw motor for coolant pump and 10kw of heaters which i split into 4 2.5 kw heaters. could any one help please???
cheers mik
what exactly do you mean by "hazardous"?
impression i get is you will need explosion proof enclosures and glanding, but fail to see why you would want lathes, millers, heaters etc in this kind of environment?
yes i know it makes no sense at all but got to plan it out will need explosion proof enclosures but what type of mcb's do u use in this environment
I'm not saying such a thing doesn't exist, but I have never come across or had need to purchase an explosion proof distribution board, and I regularly work in hazardous areas. This sort of thing is normally located outside of the hazardous zones.
If this really is what you have been instructed to do then it sounds as if your tutor is clueless. Either that or you have misinterpreted him. Hazardous area work is a specialist subject and is not something covered in any depth by the 17th regs, so unless you have had Compex training it would be crazy to expect you to spec up such an install. You would also need to know the size, location and classification on the zones, type of combustible chemicals present, temperature classes, etc.
Not to mention that you'd struggle to find an atex compliant lathe - they generate sparks and hot swarf by their very nature.
thats a fair size coolant pump....
are we sure this is for a college project?.......
