hi all new here and coulld do with some help with me water tank,
now heres my problem, i moved my tank into the loft seemed like an easy task but it all gone wrong and doing my head in now.
right here we go(please some one help me)
i have a seagull combined water tank, it has 2 water tanks on the top with water feed from the rising main to both.
then 2 over flows 1 for each tank
below there is another conection(i think it is known as hot water draw but not sure)
then it is like the tridiational tanks a conections to a coil type thing inside the tank.
now i moved it all in to the loft conected it back up to what i thought was the right pipes but then got no hot water out my taps not even cold running hot water.
i have tryed to learn from diagrams off the internet but can only find ones for old tanks with water storage in the loft, this system is designed to save space and be put in a roof space but it was not.(i do noe need it to be in the roof space)
now i have tryed many differnt ways of connecting the pipes but all that keeps happening is one of the 2 overflows ends up with hot water being pumped out of it,
on the heating pipe there is an electronic gate valve and the system is run on an electronic pump, the comi boiler will not light if the pump is not on as if there is no water getting to it,
please help me any more information you may need please ask me.
thanks everybody in advance
