Hi all
I’m getting some annoying clunking and banging from the pipes around the house. My combi-boiler is relatively new (around 3 or 4 years). There doesn’t seem to be an obvious pattern when the clunking occurs, but I have a feeling it could be mainly after the boiler it turned off.
A bit of extra info: the water pressure of the boiler is fine (about 1.5 when cold, and 2-ish when running), and the radiators all heat up quickly once the heating is switched on. The boiler was last serviced just over a year ago. The actual pipes in the house appear to be quite old-looking, but I’m not sure if that’d be a factor considering there never used to be clunking with such frequency.
My intention is to call in the engineer to service the boiler again, and to ask him to investigate the clunking at the same time. However, before I do this I’d be really grateful for any thoughts on what the cause might be. Are there any simple things I could try to fix it myself (bearing in mind I’m a total novice when it comes to boilers!)? For instance, might it be worth airing / bleeding the radiators in case there's trapped air in the system?
Oh, one last thing, the engineer who serviced the boiler before was 'corgi' registered. Am I right in thinking this has been replaced by some kind of new certification? If so, is it safe to assume that as he was Corgi registered before, he will have the new certification, or is it worth checking that out?
Cheers!
Cheers!
