Have a baxi combi instant 105HE. When turn any cold water tap on fairly hard and then off again it is is triggering the boiler to heat water. Only just started doing this. Wondered if could be an issue with mains pressure or air in pipes as sounds coming from mains feed pipe into boiler almost suggest that water is being drawn back when cold taps turned on. Does anyone have any idea what might be causing this and is it serious? No fault lights are coming on and it is heating water normally otherwise.
