Combi Hot water trigger
13 Oct 2020
First time living in a house with a combi. When I run the cold tap it triggers the combi hot water setting, I've checked the pipes and they are all connected correctly. The combi is just over a metre from the cold tap, is this just the slight pressure drop triggering as the boiler is so close to the tap. It's a Main boiler.
Not what he meant , he meant does the cold water get hot when the boiler false fires
That's right :)
single check valve on the cold water inlet below the boiler
So is firing for hot water triggered by a fall in pressure? Seems odd as the mains could be at a range of pressure. Unless the pressure switch setting is adjusted on commissioning. I always assumed there is a hot water flow switch.
That's right :)
I've just checked and it fires only after the cold tap is turned off, I'll fit the single check valve, to be honest nothing surprises me with this house, it was a rental for decades and I don't think the landlord spent one penny more than he had to. It must have broke his heart when the boiler was replaced in 2016.
