first things first please dont shout as im new and ive been reqomened to try here from a different website....
right guys in my house theres a worcester 28i junior combi boiler(first time ive ever had a combi boiler fitted lol) this was already fitted prior to me moving in.the thing is there is a consten drip coming from the overflow pipe outside which is slowly getting worst.ive just had a little look at the combi(i know nothing about them)and the pressure is at 4. bar.ive found out from other sites that is way too high and it should only be around 1.5 bar,so following some advise is ive now blead the rad to get the presure down but within seconds it was back upto 4bar.so i had a look under the boiler and the filling loop(silve breaded pipeing)is still attached so i made sure that was turned off via the plastic lever and started to unscrew the pip off,but it started to pour out water so i had to put it back on quick.
so could this valve be my problem to it over flowing and the pressure being too high?if so is it a easy job to fix ie turn system off,turn stopcock off and just undo the valve and replace? or is there anything else it could be?
