- Joined
- 26 May 2022
- Messages
- 3
- Reaction score
- 0
- Country
I want to switch from an open-vented "traditional boiler" to a combi. The size of the house & usage isn't an issue. I have gotten 3 quotes, and all 3 have given different recommendations for how to provide cold feed/boost pressure.
The 1st is to use the current cold water storage and to pump the outlet to the combi boiler.
The 2nd is to use the mains pressure, which is quite good, to pressurise the system.
the 3rd is to fit a pump (such as a Salamander Homeboost) to the incoming mains under the sink to negate any possible drop in pressure.
I am leaning towards the 1st option as the pump should fit in the space beside the storage tank, so noise shouldn't be too much of a problem. This option would also give a backup in case of water outage.
Although option 2 would be the quietest given the lack of a pump.
Any advice/opinions would be welcome.
