combi boiler pressure in toilet filler
4 Jul 2013
Staffordshire
hi folk`s.
we are both in our sevente`s and we have just had a combi boiler fitted in our bungalow. [ much warmer for us ] but now we find that the ceramic toilet cistern in our bathroom toilet fills very very slowly, it is a bottom filler that is installed, can anyone please help, me with finding which is the best fast bottom filler to use in our toilet with limited room for a high pressure combi boiler.
thank you in advance. john.
I’m no plumber but I wouldn’t think having a boiler fitted would make the toilet cistern fill any slower unless a bit of crap has somehow got into the pipe work and is blocking the fill valve.
Edit. Perhaps they turned the mains water off and haven’t turned it fully in again?
It could be as above or coincidence. Fluidmaster are a good one to fit, as are Torbeck (same umbrella company), or Thomas Dudley, however before you go fitting a new one, it might be worth checking for debris in the inlet valve. Do you know the make of toilet? If it’s a Twyford, there’s a chance the washer has a split in it, well known for slow filling.
Could be a pressure reducing valve was fitted in the water supply to the house ( to suit the boiler's pressure requirements ) and this is reducing the pressure throughout the house.
okay everyone thank you very much for your comment`s i will now have another look at my problem with a bit more knowledge.
thank`s again, john.
