- Joined
- 8 May 2017
- Messages
- 10,696
- Reaction score
- 2,899
- Country
A long way to go ?
Terry hasn’t assumed anythingNever assume the most expensive part has failed, until the less expensive fixes have been eliminated.
Could be, rough costing is £80 - 130 for plate heat exchanger (if it’s definitely this) plus fitting and carrying out essential checks afterwards, so depends on what a local would charge for this.Alternatively, will I be better finding a local gas-safe engr to repair the boiler?
Thanks for that;....no work whatsoever carried out.Could be, rough costing is £80 - 130 for plate heat exchanger (if it’s definitely this) plus fitting and carrying out essential checks afterwards, so depends on what a local would charge for this.
Has any other work been carried out recently, eg new tap? Could be failed check valve as well.
Failed check valve Chris ? Where would that be ? And how would it increase the pressure in the primary ?Could be, rough costing is £80 - 130 for plate heat exchanger (if it’s definitely this) plus fitting and carrying out essential checks afterwards, so depends on what a local would charge for this.
Sorry, my mistake, thinking of something else.Failed check valve Chris ? Where would that be ? And how would it increase the pressure in the primary ?
No worries Chris , I was intrigued to hear your theory ....bit disappointed now !Sorry, my mistake, thinking of something else.Well done Terry.
