Combi cebntral heating problem
5 Oct 2008
Bournemouth
my brother in law's combi boiler has a central heating problem, whereas the hot water works ok but the central heating won't fire up the boiler
the pressure relief pipe was also dripping she said (he called it overflow pipe)
any ideas? expansion vessel charge/problem?
Repressurise the system up to 1 bar by introducing cold water into the boiler via the filling loop - often a braided flexible steel pipe with a tap on each end - and try again!
John :)
i did that but what happens is this the gauge rises and the pressure valve releases water
Alas, thats often the case with pressure release valves....once open, they don't like to shut off again.
You could try operating the thing manually to see if it resets, if you feel confident with doing that. Often its just a turn valve knob on the thing, which is spring loaded. These things automatically open at 3 bar.
John :)
If you're luck is in, then yes - the valve should close and seal again. In reality, they have a mind of their own but its sure worth a try!
John :)
