Hi All
I moved into a new house a month or so ago and only now decided to figure out the functions on the combi-boiler. So far I’ve controlled the heating using the Drayton thermostat in the living room, whereby I can set the level at which I want the heating to come on.
Anyway, I read all through the user manual about the timer function for the heating and i was 99% sure that i understood it; however, when i did a test run the heater wouldn't activate at the time i set.
My question is this: is it possible that the drayton thermostat is overriding/interfering with the timer settings on the combi? Do I need to disable or adjust the settings on the thermostat so that I can use the combi‘s full range of functions?
Apologies if this seems a silly question, but your help is much appreciated....
thanks
thanks
