    Dismiss Notice
Combi Boiler with a small built in water cylinder
Discussion in 'Plumbing and Central Heating' started by gazz27, 1 Apr 2011.
  1. gazz27
    gazz27
    1 Apr 2011
    4
    Thanks Received:
    Birmingham
    Country:
    I am in the market for a new boiler, I currently have a 17 year old open vented system with a hot water tank. My plan was to replace it with a sealed system buying a new boiler and a new tank with the option to fit solar water heating. Now the "new" government has put back the RHI for domestic users until Oct next year I have decided to forget the solar hot water. What this means is I could save a lot of money and get a Combi boiler which should be sufficient for our hot water needs.
    What are anybodies thoughts on the Combi's which have an built in small water tank. I had budgeted for quite an expensive system so I can stretch to a better system, my main requirments are reliability and as efficient as possible, I assume a Combi meets the efficent requirment.
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    12,368
    Thanks Received:
    2,697
    Daventry
    Country:
    All domestic boilers sold in the UK should meet current energy efficiency requirements, whether they're combi boilers, heat only boilers or system boilers.
    You should have your boiler sized and specced for your house, not your current needs as you never know when your needs may change, or what the needs of a future owner will be. How many hot water outlets (baths/showers/basins/sinks/washing machine etc etc) do you have?
    There's no reason why you couldn't go some way towards your original plan by having a system/heat only boiler and twin coil cylinder fitted, that way your cylinder will be solar-ready if you decide to go down that route in the future
  4. gazz27
    gazz27
    1 Apr 2011
    4
    Thanks Received:
    Birmingham
    Country:
    My question is has anybody got experience on the these combi's with built in water cyclinders. Is there an advantage.
  5. muggles
    muggles
    28 Oct 2005
    12,368
    Thanks Received:
    2,697
    Daventry
    Country:
    The advantage is a higher hot water flow rate compared to a normal combi, but often only until the store is depleted, which can happen quite quickly on some models
  6. Sponsored Links
  7. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    What do expect to achieve with the small cylinder?
  8. gazz27
    gazz27
    1 Apr 2011
    4
    Thanks Received:
    Birmingham
    Country:
    I think that is my question, what will it achieve?
  9. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    No, it's mine, I saw it first. Go get your own question. :evil:
  10. Butchybutch
    Butchybutch
    6 Mar 2011
    151
    Thanks Received:
    25
    London
    Country:
    If you fit a decent sized combi it will give you all the hot water you need, combi's are all to do with flow rate! don't go for your entry level 24kw! Smash a 42 kw Worcester in!
    These are the words according to Butch lol
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
