Hi All,
Am thinking of upgrading the aged hot water system in my new flat, from a simple boiler and three tanks (hot, cold, header) affair, to a combi-boiler so I can free up the space the tanks are taking up.
My main concern is with water pressure. The mains pressure into the flat (2nd floor - top) appears to be pretty good (in my humble opinion). However the hot water pressure is shocking, resulting in dribbling showers
; I presume this is because the hot water tank sits floor level. There is a pump, but it looks pretty shot.
Am I right in thinking that by putting in a combi-boiler hot water should be supplied to outlets at the same pressure as the incoming mains? Hence I can expect better hot water pressure with this new water system arrangement? = good shower!
Also is there any (simple) way of measuring what the water pressure is? Some of the shower heads I have been looking at say they require 5.0bar minimum, which I think is higher than mains pressure....2-4bar ??? according to the Thames Water website...
