combi heater won't kick in , Vaillant vcw 18 t3w
13 Apr 2010
West Midlands
Went on holiday and turned water off in the house. Since coming back off the holiday , water is back on but combi won't kick in when activated by timer or by hot water tap being turned on. The pilot is on .
And the boiler pressure is ???
There is an overheat stat inside the boiler casing. That would stop the boiler firing but the pump would still run.
Tony
Checked the pressure and its 1 bar. Timer is ticking so I take it is working.No reaction to timer going on constant, or by adjusting the room stat. Thanks for any replies !
Thanks Bunnyman. have checked the pump and its not stuck, no problems moving. Have also checked electricity to boiler and its juiced up so fault could be more serious. Thanks for everybodys replys .
these r very sensitive if the pilots on it can still have tripped the 2 switches in switch box hence no power...push red button to turn pilot off wait 30 secs or so for a click them go through relighting procedure..this r resets the electrics
Sorry if I am going back but have you actually checked that the overheat stat is NOT tripped?
Tony
Thanks for replying Agile it is appreciated. I haven't check the overheat stat is tripped. How can you tell if its tripped, and if so how would you reset it ?
Its towards the back on the right hand side of the the metal PCB box and is inside a rubber dust cover.
You have to push it towards the left to reset it. Best to use a piece of wood or similar as its difficult to get your hand to it.
Tony
Got inside the metal pcb box , cannot see any switch on the rh side. I see the pcb on the lh side, the micro switches on the centre the only thing I can see on the rh side is something like a bell with RANDO on its side and this has no switch or moveable part. Hope this explains what I'm looking at . Would appreciate you continued help Tony .
Tony
Its reset from the OUTSIDE !!!
The rubber cover is visible from the front of the boiler.
Tony
Sorry mate you must think I'm a right one. Can see a rubber nipple at the back rh side of the outside of the pcb metal case. Would this be it? Do I have to have power to the boiler to reset ? As I have the front of the pcb box open is there anything i should check. there are 2 fuses in a little black plastic box to the right of the metal pcb box. Thanks for your replies. Keep the faith !
