halstead ace keeps locking out. initially just on heating but now also on dhw. Have reset numerous times on button underneath boiler but to no avail.
also burner cuts in and out on dwh supply causing showering to be ???annoying as water runs from lukewarm to decidedly chilly.
cold water pressure feed seems low even tho direct mains fed
boiler gets mentally hot... is it emergency cut off????
system seems a little sludgy could do with a flush out but is this the likely cause?
system has been bled of air
towel rail permanently open fully as bypass
pressure gauge shows system running at optimum cold at .9 running at 1.1 bar.
bolier reputedly only 6 years old and serviced 18 months ago.
totally bemused but then am only a novice plumber not a central heating engineer any suggestions gratefully appreciated.
moved to s yorks 4 months ago problem only apparent last week... only ch engineers i know live in london. diagnostics??? b4 i get ripped off
ta
loafer
ta
loafer
