- Joined
- 28 Mar 2017
- Messages
- 15
- Reaction score
- 0
- Country
Hi, I've got a Glowworm ultra com 30 cxi that has been losing pressure. The PRV drain was dripping so last week I replaced the PRV and repressurised to 1bar.
However as the central heating came on I noticed the pressure rose to around 2.6 bar. Clearly something is causing pressure to rise and then open the PRV. There is still water on the outside pipe, and each morning pressure is down to 0.4 bar.
Having researched a little, I figured this is likely to be the expansion vessel or possibly the filling loop which was left attached by the installer.
I disconnected the filling loop and both isolation valves appear to be passing. However I'm not sure what part specifically needs replacing. It also seems odd to me that both valves might have failed at once. The valves I'm talking about are shown in diagram 12.2 (D and E).
Also I checked the expansion vessel - there was water on my screwdriver when I touched the valve the first time, but I've repressurised and there doesn't appear to be any water there now. Is it possible there might be a slow leak? If so, I would expect to see a gradual drop in pressure as air entered the system, and then a rise once all of the air gets vented and the water heats up right?
Ben
Ben
