Coincidentally, That price is very close to what my neighbour paid for a new heat only boiler and associated controls from a TV advertised company. Down near the south coast in Sussex.
Love to see your face when you turn up with your £1800 install and find a keston with the concealed flue running the full length of the house, 30 year old rads/pipework and no controls fitted,needing a condense pump,wonder how far your £1800 would go then.
*depending on how old/dirty you system is
*depending on how many rads you have
*depending on how many trvs fitted
*depending on how the flue is run
*depending on a outlet for the condense being available
*depending if the controls are suitable
*depending on parking/bus route
*depending if gas run needs upgrading
If your going to advertise yourself at least be honest about it.
Danny, I am sure that you are equally capable of making up a simple circuit to turn on the immersion heater when the sunlight reaches the level which will generate 3 kW.
A simple way would to buy a light operated switch on Ebay and use it to operate a 20 A contactor. Both can be bought for less than £20.
Giving typical prices of different options enables those who have less experience of costs to get an idea of what is involved.
They are usually people who will do installations far cheaper than I will. I don't set out to do cheap work or undercut others as I don't need to.
My understanding was that these crappy PV panels couldn't pump out enough to jag up a half decent inverter, so no chance of getting 13amps @230vac. Even with a 28C day with no cloud cover!!
These PV panels have got to be the biggest waste of British Tax payers money the Tree Huggers have ever dreamt up!!
A full installation of 16 PV panels has a rated output of 4 kW.
It is therefore easily capable of supplying 3 kW on a fairly clear day. Mine certainly do!
BUT the Immersun style of device modulates the input into the immersion according to how much power is being produced by the panel.
But having a simple DIY device to turn on the immersion as soon as there is a good sunlight does not require an exact output from the panels as the grid will make up any difference if it turns on too early.
As I said before the technology is not by itself economically sustainable but those with them will make the most of using them to their best advantage.
