commercial lighting
  • Thread starter Thread starter scotteng
  • Start date Start date
S
scotteng
need to install 3 double fluorescent lights to a small commercial unit. Has very high ceilings so would need to be suspended to approx 3m from floor. Thinking of using a ctenary wire system beween the two outer walls to suspend the light fittings.
The distance to be spanned is approx 10m, do you think the weight of the three light fittings would easily be supported? or is there a better installation method
thanks
As above or Gripples.
Suspend the lights straight from the ceiling. A catenary wire will not work.
