Hiya all - had a burst about 8 months ago- fixed with compression fittings etc - dad changed a bit of pipe work - (only a tiny bit) bend as it comes down the wall to feed the washbowl so nothing i can think will effect it- anyway since this time - when you turn the hot water tap on (pipe that was effected) we get a clunking noise (nothing major as the hot water flows through) its fine when cold water is running through the same tap/pipe
as soon as the hot water comes through and the clunking stops flow gets better
any ideas please??!! - nothing major more annoying than anything???!!
