Compression fittings under the floor
5 Feb 2008
Edinburgh
I saw in some recent threads that there shouldn't be compression fittings on a gas pipe under the floor.
The 22mm pipe under my floor to the existing boiler has compression fittings and I want to have a second boiler added for the extension.
Will the RGI need to change the existing pipe as access could be very awkward unless he or she is quite thin and not too tall?
Yes, it's At Risk, which means a big red notice sayng you can't use the gas, and it should be turned off at the meter.
Even if it's not leaking? The meter was changed recently and the fellow did a leak test before he started and again after he had finished and commented that the pipe work had no drop at all.
as far as i know it is technically allowed IF you have access.
you can argue about the details of accessible, but it is never a good idea and reeks of poor quality work
There is quite good height under the floors but the wriggle through from one room to the next is a bit challenging. Perhaps time to get down there with the 6kg breaker and lower the wriggle throughs to enhance the access
It reeks of a non CORGI job by a DIYer to me!
Probably done by a vet or something!
Under the floor is one of the places they define as not accessible. You could have a removable panel I suppose.
Not done by me, Tony but done prior to me buying the house in 1995. I was under all of the floors doing the wet plumbing though which is why I know about it and thought nothing of it untill educated by reading the forum here.
depends on each house though, i had a transco guy saying it wasnt allowed even though i was standing underneath the fitting. :roll:
ChrisR can you give a page number where it says this is AR ?.
Yes I could. Source is BS6891 + Corgi TB.
Transco have some rules of their own, but thay can't apply them to anyone else's bit of pipe. Their guys aren't always hot on "our" regs.
