Just removing my old rad valves to replace with new ones.
The existing valves use reducers to accommodate a 10 mm pipe to 15 mm valve body.
The old adapter seems to come in two separate parts with a 10mm olive sandwiched in between
The new ones seem to be a single part without an olive.
http://www.screwfix.com/p/reducing-set-15-10mm/70435
Can anyone tell me if this the screwfix item is the correct part i need to fit the new valves and would /how would i fit an olive in there if required?
