At the moment l have a Conventional boiler which is a Baxi solo 3 PFL40 which serves 7 Radiators. The timer has not worked for a long time so l switch it on and off by the fused switch next to the boiler to get hot water and C/H.. only problem is l cannot have one without the other. l've been told that the timer is not the problem but both 2 Port Motorised Valves are not returning when the spring levers are moved..
So l have been thinking about having a Conbination boiler, would it be straight foward to put one of these in or would the fitting engineer have to put in more pipes/fittings , would it be a big job.
The Conbination boiler l have been looking at is the heatline vizo 24 combi boiler, would this be ok with the 7 radiators l have...
