Concealed plumbing
12 Sep 2008
Cheshire
All
I'm having a new boiler installed (by a pro) and running a new 22mm pipe to feed the bathroom installed (by me). I understand that under the applicable regs the pipework needs to accessible. What is termed accessible? I planned to build out the skirting slightly and install the pipework behind. Would this suffice or do I need clip on type trunking?
I'm a bit confused by this requirement - can you not install pipework in floor voids anymore?
Thanks in advance
Alan
a pipe should be accessible for future maintenance, your choice if you make it accessible or not, just means more damage if someone needs into the pipe. gas pipes can be fitted in ventilated voids under floor, but not under "new" floor constructions, (ie glued and screwed chipboard as there is no ventilation for a gas escape to get out)
kirkgas
Thanks. Would I be able to fit battens top and bottom but then screw fix the skirting to the battens and use cover caps to keep it accessible?
Alan
