Can you please advise if its better to use concentrated inhibitor or the standard stuff? I've heard the concentrated inhibitor can cause issues by not always mixing with water and hence building up sludge?
Whenever any inhibitor is added to a system the water should be forced to circulate around the system for as long as possible to allow the chemical to dissapate and mix with the water make sure all radiator valves are opened fully whilst doing this
I have not heared of any problems with concentrates provided the above procedure is followed and concentrates are a lot easier to get in to sealed systems
