Concord wrs boiler
24 Feb 2009
Glasgow
I need to replace the thermostat on a Concord wrs boiler which is located in an awkward position. Does anyone know the model of thermostat required so that I can purchase one before I attempt to remove the cover from said boiler.
I expect a spares supplier can trace it for you ( if its still available! ).
Are you CORGI registered?
Tony
You will probably need it to enable you to order the correct spare part !
I dont remember, but its quite possible you will need to open the combustion area to replace the thermostat. If so that would need a competent person to check that its properly sealed and that the seals are still in good condition after 30 years!
Tony
Tony
Cheers for that, I think it's time to pass the job on to someone who has a better idea of what's needed.
I know of at least 12 Concord WRS, is there a number after wrs.
Haven't looked that closly to be honest, it just says Concord wrs on the front by the pilot observation panel.
