Hi, my first post after stressing about damp issues since buying a property last summer.
Here is the situation:
1964 bungalow
Concrete Floors throughout
Bitumen adhesive & vinyl tile covering throughout
Damp rising up through the concrete (fluffy salts)
I believe I probably need a surface (epoxy) dpm solution.
Vinyl tiles and bitumen both tested - both contain asbestos. I am paying for the vinyl tiles to be removed by specialists. The bitumen has to stay because its too expensive to remove.
Is it possible to apply the surface dpm over the bitumen? Perhaps some kind of epoxy primer first...?
What about stud walls - would the surface dpm need to go under the studwork, otherwise all moisture will migrate to gaps in the DPM ie under stud walls?
How to link the new surface DPM to the (presumed) DPC in the walls? For solid internal walls should I expect to see a DPC also?
Finally, the house feels damp at present. We have a de-humidifier running constantly. In your experience, does the surface DPM solution actually stop the problems re damp floors and create a dryer environment? Or would another solution be better?
Sorry for all the questions - hope somebody can advise - its been abit of a nightmare discovering these problems we never knew we had! Thanks in advance for any help
1964 bungalow
