Right, as usual I have had a look around and cannot find anything to quite match my question!
I have an existing hardstanding which is now the base of my garage, which I have built up around it. The hardstanding has a slight slope on it allowing water to 'flow' into the garage rather than encouraging it to stay outside, so I intend to concrete over the existing to correct this.
Looking on paving expert website hardstandings should be 100mm thick minimum, the existing hardstanding meets this requirement.
My question is, I want to put a DPM down and then concrete over the top, should this new concrete be minimum of 100mm thick too or can it be slightly thinner due to the 100mm existing beneath it?
I'm not sure if the DPM will upset the characteristics or wont make the blindest bit of differece, hence the question.
many thanks.
C.
many thanks.
C.
