    Dismiss Notice
Concrete mix for pointing patio
Discussion in 'Building' started by canetoad, 26 Feb 2009.
  1. canetoad
    canetoad
    5 Sep 2008
    12
    Thanks Received:
    Fife
    Country:
    I've had a new patio laid, which is only 3 months old and when O hosed it off the other day some of the pointing has crumbled and come away. Not impressed! Anyway, I wanted to know what the best mix of sand (sharp or soft) and cement would be to replace it? Pavers are Indian limestone apparently.
  2. SUPERSLASHER
    SUPERSLASHER
    2 Jan 2009
    59
    Thanks Received:
    3
    Sussex
    Country:
    I have found the best mix for pointing any slabs is 2 sharp sand 2 building sand and 1 cement with 2 capfulls of pva neat i use febond. Mix up sand and cement dry and when ready to put water in add the pva. Make sure you do not put too much water in or you will stain the slabs. Then you can start to point in. I always chop it in to the joints with a gauging trowel do about 5 meters and then come back and stripe it up with a small tool. Leave to go off and then brush off with a soft brush.It will not crack or shrink back. :) S/S
  3. noseall
    noseall
    2 Feb 2006
    37,631
    Thanks Received:
    2,419
    Staffordshire
    Country:
    great advice....except the pva bit? :confused:
    do you mean plasticiser?
  4. SUPERSLASHER
    SUPERSLASHER
    2 Jan 2009
    59
    Thanks Received:
    3
    Sussex
    Country:
    No i never use plasticiser in pointing mix only in rendering. I have found that febond pva is the best in pointing mix. Never any come backs with it so i stick with what i know will work. :) S/S
  5. noseall
    noseall
    2 Feb 2006
    37,631
    Thanks Received:
    2,419
    Staffordshire
    Country:
    i can not see the benefit of the pva?
    enlighten me please.... :?:
  6. Sponsored Links
  7. SUPERSLASHER
    SUPERSLASHER
    2 Jan 2009
    59
    Thanks Received:
    3
    Sussex
    Country:
    I always use pva when pointing INDIAN stone and smooth sided paving as the pointing sticks to it a lot better when pva is added you dont get any hair line cracks along side the slab/pointing. With the plasticiser it does not seem to take to the slab in the same way as the pva .I suppose it is what i am used to useing as well :) S/S
  8. Alastairreid
    Alastairreid
    21 Nov 2008
    6,064
    Thanks Received:
    918
    uk
    Country:
    Makes sense to me :D .............will try your method out....(in the spring)
  9. noseall
    noseall
    2 Feb 2006
    37,631
    Thanks Received:
    2,419
    Staffordshire
    Country:
    ...So the pva helps deal with shrinkage?
  10. canetoad
    canetoad
    5 Sep 2008
    12
    Thanks Received:
    Fife
    Country:
    Thanks for the advice, much appreciated.
  11. SUPERSLASHER
    SUPERSLASHER
    2 Jan 2009
    59
    Thanks Received:
    3
    Sussex
    Country:
    Sorry noseall for not answering your question earlier but yes it is to do with the shrinkage. :D S/S
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
