    Dismiss Notice
Concrete Mix
Discussion in 'Building' started by Reedswood, 28 Jun 2013.
  1. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    I've a bag of grey concrete mix, and want to know if it's applied neat (on it's own without water) whether it's waterproof?
    The problem is, I've just used a Interior/Exterior filler from wickes, and didn't read the small print that it needs an additional oil based paint to apply on top to make to 100% waterproof, so my friend has just done quite a bit of guttering re-pointing with just the ready made filler, and within an hour of completing the job it began to rain and you can imagine what happened...yes, it began to sag in areas, so quick thinking today, we decide to reinforce the soft filler with neat concrete powder and force it back in so it can at least be rock hard given some dry weather this weekend.
    Will this make it waterproof or?
  2. Sponsored Links
  3. stuart45
    stuart45
    13 Sep 2008
    2,937
    Thanks Received:
    418
    Somerset
    Country:
    What gutters are they? eg. Iron or plastic.
    • Thanks Thanks x 1
  4. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    it's where two sections of the roof meet, and it's got a lead gulley down both sides and it's the pointing that's crumbled, so just repairing!
  5. stuart45
    stuart45
    13 Sep 2008
    2,937
    Thanks Received:
    418
    Somerset
    Country:
    Sand/cement mix is better if it's the tiles at the valley. Neat cement tends to crack.
    • Thanks Thanks x 1
  6. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    thanks for the reply...where the filler is soft he's trying to blend the concrete in with it so can't add sand now, so just wondered if there's a waterproof solution I can apply over the repair once cured?
  7. stuart45
    stuart45
    13 Sep 2008
    2,937
    Thanks Received:
    418
    Somerset
    Country:
    • Thanks Thanks x 1
  8. Sponsored Links
  9. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    not too keen on black really, is there something grey or transparent?
  10. tony1851
    tony1851
    23 Feb 2012
    9,714
    Thanks Received:
    1,453
    Manchester
    Country:
    Why don't you just do a proper job on it by taking out the old filler and pointing with a 1:3 cement/sand mix?
  11. pred
    pred
    2 Feb 2011
    4,612
    Thanks Received:
    36
    Bristol
    Country:
  12. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    @pred, it's the mortar that's crumbled above the flashing adjoining the titles; just done the repair, all I want now is to waterproof it all with a suitable solution!
  13. ^woody^
    ^woody^
    3 Sep 2006
    29,342
    Thanks Received:
    3,789
    West Mids
    Country:
    It won't be waterproof
  14. Reedswood
    Reedswood
    24 Jul 2012
    28
    Thanks Received:
    Sussex
    Country:
    all being well it will be after I use: Thompson's One Coat Water Seal Ultra
    thanks all for your input! I'll post feedback after 6 months! ;)
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
