I'm planning on adding more concrete on to an existing slab, it's currently 75mm I will be bring it up to about 125mm. Do I need to do anything to the existing slab before the pour, I thinking would a PVA solution be neccessary.
If the existing slab is internal like a garage etc then wet it thoroughly and many times in the day before your pour, the suction is enormous and will dry your new concrete so fast it will be very hard to float/ finish properly.
