Condensation from metal roof
5 Feb 2003
Hi
My son has a small work unit on a farm with a metal roof. The condensation dripping down from the roof is a big problem. Is there a quick fix? I remember a spray on insulation but cant remember what its called and have no idea if its any good.
5 Feb 2003
it needs a ceiling to keep the moist indoor air away from the cold metal roof.
Yes but it hasn't got one...... anyone know if the spray foam will work? Its about £500 so would be good to get a heads up....
10 Feb 2007
Cumbria
Its good when on but contains isocyanate catalyst for the curing process. The pro's use line-fed air to breath and auto-mix guns. If you have plenty of ventilation (alot) then it may be ok to spray with a vapour cartridge mask/goggles/rubber gloves. Just like your B&Q expanding foam it sticks like s**t to blanket so keep it off your skin!
23 Feb 2005
Surrey
Could try fixing some breathable felt under the roof. Making sure the edges go out under the eaves, this should act as a one way barrier.
The vapour will pass through the membrane, condense on the roof, drip down and run out over the walls.
I painted the underside of my asb. roof with bitumen paint. That was a mistake :rolleyes:
