- Joined
- 17 Dec 2018
- Messages
- 607
- Reaction score
- 15
- Country
A company is proposing to install internal wall insulation on the external walls of my family members house.
The property is a victorian building with solid walls and lime plaster
The company state that they will install battens onto the wall, then place insulated plasterboard on top. This will then be tape and jointed before plastering
What I want to know is that if the existing plaster is hollow
1. Should I remove all the lime plaster, so that they attach the battens directly to the brickwork?
2. Should I insist of plastering the plasterboard with lime plaster (for breathability) or will gypsum be okay?
3. The property needs a rewire plus additional sockets on these external walls. So Should I chisel out the walls now for the backbox? or is the void between the plasterboard and brick work enough to install a dry lining backbox
4. If the plasterboard is cut e.g. for the backboxes, will this cause thermal bridging/ condensation and possible mould behind the plasterboard?
