- Joined
- 13 Dec 2008
- Messages
- 8
- Reaction score
- 0
- Country
My neighbour upstairs has just had a condenser boiler fitted and I have a few issues.
The contractors have run the drain pipe outside down the front of my flat. Ignoring the fact that she is in breach of the lease by doing this, I read up on it a bit and it seems the installation is in breach of regs anyway.
1) The pipe comes out of her 1st floor flat, runs horizontally for approx 3m, then down approx 2m. The pipe is 22mm plastic, they have lagged it in grey foam. Q: Should it not be wider diameter pipe for such a long run? Also it is only supported twice along the entire run.
2) When it comes to ground level they have taken a bit of flexible piping, then squeezed it so that it fits between the grates of a drain, so at that point it is uninsulated and only maybe 6mm or so wide. Is that acceptable?
She assures me that her Plumber tells her the installation is in line with CORGI regs, but I find this hard to believe. I have asked here to have the work redone so that is discharges into the internal waste water system in her flat, but she seems unwilling.
Any pointers would be gratefully received!
Many thanks for your time...
