The proposed building is a small bungalow with a mezzanine floor in the roof space over the entrance door in the brick / stone gable end.
Is it permitted to install a condensing boiler on the brick / stone gable end wall above the entrance door ? Ridge will be above the boiler and about 6 feet above mezzanine floor.
If the hot water tank is also installed at that level ( ie above all taps ) what problems could this create ?
Combi boiler is not an option as heating will be supplemented by re-newable sources.
